Discuss Bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
like for like replacement is maintenance and as such not notifiable. a MWC is optional. but changing a pull switch for a shower is not good. you end up with 2 showers and no pull switches. :smilielol5::smilielol5::smilielol5:
As tel says, a like for like is classed as maintenence. I would test the circuit as well and inspect to make sure the cable size, MCB size, and shower rating are all holding hands nicely.
Has the existing one melted then?
If so, I'd thoroughly recommend tidying up cables, thru crimping and then fitting a blanking plate to the patress. Saves exactly the same thing from happening again.
Through crimp the cables job done :stuart:
Or fitting a Crabtree 50A version - never seen one of these fail!
I have to agree regarding the quality of those units, their screw terminals are however subject to the same expansion and contraction as the screw terminals in a cheap bakelite isolator, a by-product of the heat generated by the current (teaching you how to suck eggs I know Murdoch).
I think the reason they are "more robust" is down to the fact that that entire design allows the installer to use up to 10mm cable, and be able to tighten the screws properly, and not "disturb" the connections when the cover is screwed back on - unlike most other badly designed 45A pull switches!
That's exactly the problem with switches that require the "twist and shove" method of getting them on. You never know what state the termination is in after it's been screwed back. The amount of boxes I have cracked with bent 10mm conductors too.....
The Crabtree ones are perfect.
i ihad to replace a crabtree the other week for a mate. it was fitted by me 16 years ago. not a bad run.
i give a lifetime guarantee. " if you don't use it, it won't ever wear out".
Reply to Bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
A pull-cord shower switch is located in Zone 2 of a bathroom, including the ceiling base containing the electrical connections. With a little...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
