Both fitted ?
So to prevent it from ever happening you would fit the din-rail blanks that are the shape of the MCB's in the first place Yes.
no, i dont see the point, our db's have locks on them so only used by a competent person.
i usually use the ones in the cover.
there are usually no exposed L,N bars
The point is taking pride in your work and doing the best job possible. Not just doing the minimum necessary and then making excuses about door locks and things not being exposed.
I'm not sure that Schneider do din rail blanks to fit these boards, I don't think I have ever seen them.
I can confirm that the Schneider clip on blanks as shown are very sturdy, not like the flimsy ones by other brands that are easily pushed in or picked out. I tried to remove some of these blanks in a Schneider domestic CU in a wholesalers the other day. I couldn't do it.
I always use din rail blanks in all my domestic boards, but I use Hager for those and the din rail blanks are readily available.
you have to push them from inside out to get them out. they slot under then clip back
Sorry to go against the grain here but other than lack of obvious circuit ID there is nothing visually wrong here, clip in blanks are totally acceptable and Schneider boards of this brand have a lock off busbar stump that if not used wont be energised, it takes a total idiot to enter the board and energise an unused stub... idiots are dangerous playing with any brand, so regardless of the blank falling out, getting nuked or the plumber attacked, the user cannot stick his finger in to a live busbar pin and get a shock.
Its not bad practice, unprofessional or an eyesore its perfectly acceptable and common and to my knowledge Schneider do not make an alternative to the clip in blank
I bet there is a circuit chart for that somewhere in a office etc..
a easier way to work that out is how neat its been done inside, if its neat you know its a decent spark and sent a circuit chart in with the test cert, looks pretty brand new, maybe a unfinished job???
View attachment 26691View attachment 26692View attachment 26693
To my absolute amazement the DB and all circuits illustrated above have I am informed been tested to 17th edition standard. How many 17th edition problems can you spot here? I am wary of just how many other issues will be discovered when I start doing a few circuit tests of my own! Though I have to trace the circuits first! Quite unbelievable sadly there are a lot of 'companies' who do such shoddy work!
Jesus from the way this thread title was written i was expecting a bit more than no DB or circuit ID's being present.
Ok come on then, how many 17th editions problems can you spot, because i'm trying to work out your statement on what your ''Absolute Amazement'' is all about???
Agreed.... What a let down
Wait till he takes the cover off :49:
Well going by the OP, even he hadn't taken the cover off the DB at time of writing, but still seemed to be in total amazement at the lack of panel /circuit ID's. If it is a mess inside, ....well i'm half expecting the guy to have a heart attack!! lol!!
I have never, In the last decade worked for a firm or subbed to someone who supplied dinrail blanks. people just dont want to pay it.
I much prefer din rail blanks like the ones I use when installing Hager. Sad thing is that Sparkyjoe is right, people do not want to pay and often supplier prices are so bad that spare mcb's are on a par
Only issue I see is a lack of labelling. Installer may have the ****test handwriting going and typed up, but it didnt get attached. May find as soon as you take the cover off they have written down that centre strip instead. If thats a worry to you you should see half the jobs I have to test for signing off
tp board with 3+ cores in every breaker?
ive seen that a couple times as well as boarded over boards
it was a job with one board on every floor, the guys could see where the board was fed from but couldnt find the board.
they found it by checking every board and proving supply etc, in the end it was pure look it was found
