C
clucky10
Hi,
Please bare with me new to this, I have a belling electric oven. The problem is the grill, I can have it on so it heats up fine no problems there, but as soon as I put some bacon under and leave for a few minutes it trips my electrics. I have a cover on it so the electricans have been out now 3 times, replaced the element, thermostat and the fan. It only trips when cooking bacon etc so electricans can't understand whats causing it as they've replaced everthing possible. Does anyone else have any ideas on what could be the cause? They've also checked all my wiring and connections etc thinking of going back to a frying pan. Sick of calling them out.
there's that much water in modern bacon, it could be water vapour getting into the connections in the grill. try buying dry cured bacon. check for horse DNA though.
Is the fuse/mcb the correct size/rating for the cooker, sounds to me that as its getting hotter it tripping out
Hi,
Thanks for your reply, could it really be water vapours getting into the back of the element, the grill element looks quite a snug fit and I would'nt have thought it's very safe if vapours could get into the back of the connection. I did'nt mention before but you have to cook with the door closed on my grill and it does create quite abit of smoke but everytime I mention this to the electricians they say its normal.
Hi, yes it has the correct fuse and the electricians who come out say because its controlled with a thermostat and this is working fine there is now way it can over heat.
I didn't say the cooker is overheating, I said as its getting hotter (the element), this may be causing the breaker to trip, what size is the breaker?, what rating is the oven?
I take it you mean the Rcd trips?
Try some toast instead of bacon and see what that does.
If it doesn't trip then it's toasted teacake for you from now on:)
Hi had a similar problem on another cooker brand the other day. Turns out the insulation on the back of the appliance is covered in a foil, when the oven got sufficiently hot the foil was curling up. enough to make contact between neutral and earth on the back of the grill element. Just an idea use insulation resistance test and move different parts of it about to check when the fault occurs. Intermittent faults are hardest to find. Hope this helps
