Well maybe since every electrician I’ve seen is using one. 4ah batteries shud be okay this one electrician I was working with had 1.0 or 1.5 csnt remember exactly but it was low. Also best time would be around now/christmas to buy any tools/ drills since theres sales so might aswell save some £ and but stuff nowAsk yourself if you really need an impact driver….
The 200 kit from screwfix is possibly the best price you’ll find…. Although the battery’s are only 4Ah.
Dont they use the spade bits on them to drill holes through joists for cable running? Or drilling the ceiling for spotlights, socket entry holes etcWhat would you use an impact driver for? I have one but have never used it.
Most likely want to get into domestic firstA lot is going to depend on what you're going to be doing, If you're just doing down lights and drywall stuff then you could manage with very little.
If you're going to be doing a wide range of domestic work such as in older properties etc where you have to deal with cob walls, lathe plaster, then you're going to need a wider range of tools.
I personally find Erbauer stuff to be good value for money.
If you're putting screws in wood, then generally an impact driver is better for lots of reasons.
What sort of work are you going to be doing ?
