Discuss Best Domestic CU For Complete RCBO Install in the UK Electrical Forum area at ElectriciansForums.net
S
SKY
Hi Chaps
There will be lots of opinions I guess but what do you guys regard as a good (or the best) domestic CU for a full RCBO install (8 circuits)?
Looking ease to work with as well as space at the top of the RCBOs.
Thanks All
Sky
Wylex supply a kit with 8 RCBO's at a decent price, the main switch is moved over by 2 modules to allow easier wiring of tails/fly leads. Think its a 16way unit with 12 usable ways.
Failing that, MK have always provided the most spacious fuseboards!
I like Hager boards. I personally think there is plenty of space above the MCB/RCBO and they look asthetically pleasing
If you get a GE Board they have the new miniature rcbo's which are not much bigger than an mcb I don't know about price though, otherwise MK have plenty of space and are not as expensive as you would think.
Like the idea of the RCBOs that are compact by GE.
They are in toolstation but are C curve only - have you used C curve in domestic before?
Using type c devices will bring down your max permissable Zs levels a fair bit so i wouldnt advise it unless you already have test readings for the circuits beforehand.
Reply to Best Domestic CU For Complete RCBO Install in the UK Electrical Forum area at ElectriciansForums.net
Hi Doing my first Inverter and Battery install on a domestic property having just completed my EESS course with LCL. Question is how do I...
6K
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
