Discuss Best gland pliers in the Electrical Tools and Products area at ElectriciansForums.net
We have numerous techniques and tools for working with gland and bush nuts. We have an extensive range of C-spanners, crowfoot wrenches, offset and flanged open spanners etc. We also make or own spanners from time to time, the more commonly used are slogging spanners like these that we cut and converted into open ended.
Finally, for very awkward access, we also get nuts made specially from s/steel with a castellated edge that can be tightened with an appropriate punch. They kinda look like this but without the chamfer at the outer edge.
In the last few years we've had more problems with the gland and bush bodies than the nuts, they don't make them very strong anymore and they tend to disintegrate too easily.
I know what you mean. Bushes where the head snaps off, or they round off if you even show them a spanner!
Yeah, some of them are appalling quality, they just collapse if you show them pliers or grips, the thickness of the material used is very inadequate and it's very soft.
God read this lot and weeped! I've got eagle beaks for glands as well as having the correct large spanners for 20, 25 and 32mm (although some gland makes are different). We would get an arse kicking if we marked a gland! I got a complete set of box spanners as well which are pretty much the only tools to use on gland plates in the bottom of panels especially when they rammed, saves lots of missing chunks out of your knuckles. At a push I would use good quality adjustables but never pump pliers. As for bushes these are a right PITA, I have got the black bush-king spanner but its not brilliant TBH, I usually use slim 20mm socket on 3/8th ratchet.
bloody rough as, the lot of you! for glands upto 25 I use bacho widejaw adjustable spanners. for anything above that I use what are known as eagle beaks: on the sites ive worked on, you would be no longer required if you marked glands because of using waterpump pliers.
stupid comment, 'eagle beaks mark glands just as much as wrenches etc, I'm sorry but you fall into the cowboy category also, you would not be allowed to gland with out the correct size spanners with my employers (also my dads TV is way bigger than yours, JUST SAYING)
Don't think he's been on here for 8 years.
I Keep hearing this method but can't visualise it, any videos?
Knipex Pliers Wrench for me, fiddly to get used to but I wouldn't go back now
hammer and driver..... you place the driver against the nut and hit with hammer to turn the nut. move round the fces till nut is tight. dismantling is same procedure in reverse.
Reply to Best gland pliers in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
Inspired by another thread, which I don't wish hi-jack. Can anyone recommend a decent, relatively low price punch down tool? I've had a cheap...
Hi All, Just started upgrading all my out building for power and data and i was wondering rather than cutting off the ducting at floor level, do...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
