Discuss Best network cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all!
Just wanted to get everyones opinion on the best CAT5 & CAT6 cable which you’ve used on jobs.
I have been using VueNet Cat5e and really like it, not had any problems and is at a decent price.
Let me know what you think :smiley:
Stick to cable which is pure solid copper and not CCA or CCS (copper-clad aluminium/steel).
Cable with a nylon rip cord is annoying, ethernet cable doesn't need it. It causes an extra step having to cut it off.
For time saving, cable which has the pairs twisted in a 'left hand lay', rather than the usual right hand makes a surprisingly big difference if you have loads of them to do. When you separate the pairs to punch them down, it seems so much more intuitive to undo in an anti-clockwise direction. Right hand lay means you have to go clockwise to undo, which is unnatural, becomes fiddly and wastes time. HellermannTyton cable is left hand lay(and no rip cord).
The stuff that the data monkeys don’t cable tie to the outside of your perfectly formed and newly installed conduit.
Hi rsgaz!
Totally agree with the pure solid copper - have used a few in the past that wasn't and paid the price. That's one of the reasons I've started to use VueNet!
Never had an issue with the rip cord and would cut off if it wasn't needed
Thanks a lot for the advice :)
Is VueNet left or right hand lay OOI?
This is Belden, left hand lay...
https://www.markertek.com/productImage/450x450/BL-7929A-1000GY.JPG
(not a rip cord BTW, it's the drain wire)
Reply to Best network cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi All, I want to install two PoE cameras under the roof outside. But I don't know how to run a cable, drill through the wall or through the PVC...
Hi guys Iam currently studying for my level 1 electric installation . Which btw I am loving. I've always been decent with DIY. But also I have...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi folks, I have been out to quote for a soffit lighting job. I have done jobs like this many times but usually only installing lights in the top...
