Discuss Boiler not firing up in the Central Heating Systems area at ElectriciansForums.net
DIYfan
Hi, I've got a problem with my boiler I was hoping someone might know what it could be (apologies for me explaining in very simple terms), we've been away for 10 days and have just returned and when I switched it on it's not firing up and there's no flame visible through the hole. It's a Glow worm 40ff, 18 yr old conventional boiler. It had the pcb replaced about 6 months ago and the engineer said it should have a few more years left.
When I tried to boot it up for hot water or heating it won't automatically click and kick in and light the flame, it makes one loud click which it always used to do then it used to do another click or double click and boot up igniting the flame but isn't doing that now. It sounds like it's trying and the fan is running.
I've switched it off and on at the wall a few times and turned the knob on the boiler itself off and on, high and low but no joy.
I'm going to call my regular boiler engineer out tomorrow unless there's anything that can be suggested here, thanks.
All I can suggest is to let it strike a few times to see if the pilot light lights up . If not it is time for professional help
Would usually light but not maintain the flame . The thermocouple needs heat to sustain the flame and keep gas valve open.
Sometimes when the system has not been used for a while valves stick closed this happens a lot with heating valves after the summer when the heating has not been used however you can hear it clicking to light up it could be something similar inside the boiler time to call a boiler engineer
That makes sense, thanks
Does it not light then the boiler shuts off if that happens?
if the pump isnt running its a calling issue eg not calling for heat so prog or room stat if no hot water as well prog
but if the pump is running either overheat or internal boiler fault (somthings holding it off eg no pilot light on the older ones)
under the front cover any lights on op?
The boiler itself doesn't have any lights to light up, it's controlled by a drayton lifestyle lp522 programmer which is all lit up as normal
Reply to Boiler not firing up in the Central Heating Systems area at ElectriciansForums.net
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road. 2 - Reason for call, heating not...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
