This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
if the pump isnt running its a calling issue eg not calling for heat so prog or room stat if no hot water as well prog
but if the pump is running either overheat or internal boiler fault (somthings holding it off eg no pilot light on the older ones)
under the front cover any lights on op?
The boiler itself doesn't have any lights to light up, it's controlled by a drayton lifestyle lp522 programmer which is all lit up as normal
so ultimate version
the front panel should pull off (no screws) there a red button right of the dial press this in if its out
This is a photo, should I switch it on and press the red button to the right of the dial? DSC_0002.JPG
The pump is in the airing cupboard next to the hot water cylinder, how do I know if the pump is running/working?
yes you should be able to feel it should be making a vibration / light on
Yes it was vibrating lightly and I could hear water running through it and it was slightly warm, I did heat the tank with the immersion heater earlier, not sure if that matters
