So does he have an EIC or minor works cert for the new work?
i don't think so he didn't mention when I asked about why the spur was that close to the drainer, I've always been under the impression that accessories should be kept away from sinks and draining boards
One of the first thing you should ask for when doing a periodic inspection is previous certs, especially recent ones. Ask for the certs, make a note on the report if there are none to the effect that recent work has not been carried out to BS7671, code the FCU referencing specific regulations if you see fit, job done.
The FCU is very likely to be splashed with water, in fact it will be if it's so close, so at the very least it is unsuitable for the environment, unless it's suitably IP rated.
Good morning guys and girls
I have attended a kitchen rewire this morning to test a install buy a 3rd party.
The boiler spur is directly above the draining board I'm quite sure this shouldn't be the case. I've been told by the installer that "it's fine it's rcd protected" is this just waffle to get me to sign it off.
Surely it's the same principle as a light switch inside a bathroom?
Lets put a double socket over the bath to plug the fire in well its RCD protected it's fine !!!!!!!!!
Anyone who correctly uses a possessive apostrophe in that sentence is ok by me. Grammar nazis rule! Daz.
Nice, nice, very nice. Grammar spot on,the rest, well, the mind boggles.
Wasn't Rosco a DJ on radio Caroline?
I take 300mm as a basic rule as above as no direct reg stating distance,regarding testing if I have read the posts correctly you work for a NICEIC D.I. firm.NIC don't do 3rd party, kitchen fitters do work you test it as condition report and your company notifiys it as they done work to building control via NICEIC web site this as well as the cert being forged as satisfactory this is not correct.
