- Reaction score
- 282
Best you give it an unsatisfactory then or have you been told to give it a satisfactory?
Discuss Boiler spur location in the UK Electrical Forum area at ElectriciansForums.net
I have put in as unsatisfactory, but what happens when it leaves the office is anyone's guessBest you give it an unsatisfactory then or have you been told to give it a satisfactory?
Lets put a double socket over the bath to plug the fire in well its RCD protected it's fine !!!!!!!!!Good morning guys and girls
I have attended a kitchen rewire this morning to test a install buy a 3rd party.
The boiler spur is directly above the draining board I'm quite sure this shouldn't be the case. I've been told by the installer that "it's fine it's rcd protected" is this just waffle to get me to sign it off.
Surely it's the same principle as a light switch inside a bathroom?
Hi - I use the IET Electrician's Guide to the Building Regulations and Figure 5.2.2 may be relevant?100mm 1 tile
Nice, nice, very nice. Grammar spot on,the rest, well, the mind boggles.Anyone who correctly uses a possessive apostrophe in that sentence is ok by me. Grammar nazis rule! Daz.
I do take pictures then email them to myself as I've had that beforeIf you don't trust your employer ... keep a copy of how you submitted it.
Radio Caroline? I don't know who that is but I bet she's "sweet"Nice, nice, very nice. Grammar spot on,the rest, well, the mind boggles.
Wasn't Rosco a DJ on radio Caroline?
It was on Medium Wave, it used to fade in and out again. A bit like 3rd party certification when you have not even seen the first fix.Radio Caroline? I don't know who that is but I bet she's "sweet"
Presumably AC given that he is using NIC forms for an EICR (unless he has an EICR add-on for DI).if I have read the posts correctly you work for a NICEIC D.I. firm.
you can be a niceic D.I. they use the purple certs red is for AC and green for anyone to purchase the A.C. & D.I. have tracable numbering.Presumably AC given that he is using NIC forms for an EICR (unless he has an EICR add-on for DI).
Not for EICR I don't think. I think EICR is excluded from the scope of DI unless you do a further assessment for it.you can be a niceic D.I. they use the purple certs red is for AC and green for anyone to purchase the A.C. & D.I. have tracable numbering.
think your right on that neverless a nic D.I. should not be doing this.Not for EICR I don't think. I think EICR is excluded from the scope of DI unless you do a further assessment for it.
but that specifically refers to sockets, not FCUs.Hi - I use the IET Electrician's Guide to the Building Regulations and Figure 5.2.2 may be relevant?
Reply to Boiler spur location in the UK Electrical Forum area at ElectriciansForums.net
