U
uksparks
Hi,
ignore the price of it, has anyone on here got one?
BOSCH D-TECT150 Digital Wall Scanner: Amazon.co.uk: DIY & Tools
you can get it for under £400.
anyway, I was hanging a TV in a wall the other week, one of those metal frame stud wall things, anyway, customer says here use this, a wall scanner to find the metal verticals to fix in to... Ok I say but I don't trust them one bit.
it suggests there are two verticals approx 400mm apart which I thought ok, maybe it's true, when I dug a hole in the wall to put the dry line boxes in, there were none insight, I even did it again directly below where I had just cut a 2 gang dry line box in and if said it was there.
i said to the bloke, I said I didn't trust them.
anywag, if you spend £400 notes on one, are they better?
As an Amazon Associate we earn from qualifying purchases.
got the older model and found it useless,, maybe not used properly maybe not.
currently just using a very very strong magnet, value for money.
