Hi, Yes I am confident that I can do the rewiring - I already have boxes of the various Wago connectors - both the push fit and spring lever ones. So I will completely remove the Ballast, use the space to fit one of the Wago junction boxes. And then add behind the mirror a laminated notice saying that only mains LED tubes can be used. What surprises me are that LED tubes that can the Ballast are around £6-7 whereas ones that you can use with Mains are £20-24!I would engage the services of a local electrician and have them rewire the mirror to use these:-
Lamps - Tube - T5 Tube - Crompton Lamps Limited
www.cromptonlamps.com
Unless you feel confident you can undertake the work safely yourself... and for the record, safely does not involve using choc block terminal strips and PVC tape. For this, safely involves decent wire connectors such as the Wago or Ideal lever connectors, or if the cabling is solid single strand copper, the equivalent push fit connectors (I would go with Wago's personally).
