Discuss bt line annoying my dimmers.... in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
as above , installed dimmers on to my lights and the phone seems to hum, but on further investigation, the bt cables are old and comming down behind dimmers and switch wires..... any good easy solutions for me soldiers ...
- - - Updated - - -
isit re- cable new bt line???
If separation is not possible then use a shielded cable for your BT connection. That should solve it.
do you reckon its just the connections where sheath has been removed picking up the flux.........
- - - Updated - - -
aww , i get now..... rewire with shielded cable...
- - - Updated - - -
Have never tried this so don't know, but the bt cable will be 3 pairs of which only two cores are needed - try tying the other 4 cores to ground at each end, some cheapskate shielding!!
Worth a try, I'll be interested to hear if it solves the issue.
Another trick is to double up the pairs, i.e punch down 4 wires at each end instead of the two.
Or you could try punching down 3 wires 2,3 & 5 I know originally the third wire was just to stop ring back on the old dial phones but have been told it reduces clicking often heard on some lines too nothing to loose
Reply to bt line annoying my dimmers.... in the UK Electrical Forum area at ElectriciansForums.net
Hi All Struggling to install a bog standard light switch due to getting confused by different coloured cables. I'm an avid DIY but never had...
I just rewired my kitchen CFL T8 fixture with direct wire - double ended Sylvania A/B type LED tubes, no more ballast. One single 120V 15A line...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how my oven is currently wired up, followed by 3...
