Discuss Cable tracer / fuse finder in the Electrical Tools and Products area at ElectriciansForums.net
Sintra
Staff member
Supporter
As per the title I am looking for recommendations for a new fuse finder / cable tracer. Not worried about the price more the accuracy of the instrument.
I've got a martindale unit that needs power at one end for the tone to generate. The socket and see unit has batteries that you can use on a dead circuit, might be useful.
I've only used mine once. I generally use my warbling socket tester and listen for the silence but as I'm domestic that's most often possible.
See what others recommend.
ihave a martingdale, the bleeper has stopped working. martingdale says it's not worth repairing.so much for after sales service.
Power at one end is fine but I need it to be spot on accurate at the other.
So I eventually went for the Martindale CD1000 unit. Have been using it for the last 3 days with spot on accuracy in what can only be described as a challenging installation as it was overseas and by no means to UK standards. At a smidge over £300 it has paid for itself at least twice over. Roll on next weekend until I have to go back and complete the survey lol.
Have to say that looks like a rather nice bit of kit :)
Was going to go for the Mardindale FD650 at around £100 ish but glad now that I got the higher end model.
Reply to Cable tracer / fuse finder in the Electrical Tools and Products area at ElectriciansForums.net
I've got a Fluke 2062 cable tracer. Cracking bit of kit, but very expensive, and isn't getting used very much. I might be open to renting it out...
Hi anyone got any advice on the best cable tracer Currently we have a fluke tracer but it seems to pick up everything apart from the cable we are...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi all, as in the picture, when connecting a 230V cable to a db like this, is there a legal requirement to install external RCD unit? Also, if the...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
