Discuss cable under plaster board in the Industrial Electricians' Talk area at ElectriciansForums.net
M
mikeyg
on a new installation, do you have to channel the wall out before running cables down or can you just nail the cables to the wall (with protection)then plaster board over?
you can either clip the cables first or sheath (cap) them prior to boarding. Remember to still follow permitted cable routes though;)
my recommendation would be to cap the cables then you can for example dot and dab the plasterboard ontop of the existing wall. The thickness of the dabs will allow you sufficient space between the existing wall and the new plasterboard where your cables will be sitting.
Sounds very promising for faults :)
Its ok to clip the cables direct to the wall as long as they follow the safe zones as stated by Cirrus
I often use plastic capping ( or sheathing as I have always called it )
It does nothing as far as mechanical protection of the cable is concerned but it is neater and more convieniant than clipping
It also makes it easier for future change of cable if required for some reason
Reply to cable under plaster board in the Industrial Electricians' Talk area at ElectriciansForums.net
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
