Discuss Can I drill through a 4 stud thick column to run one 12/2 wire? in the UK Electrical Forum area at ElectriciansForums.net
Changord
I'm running one 12/2 wire through a wall and I ran into a structural column. It is 4 studs thick. Can I drill through this column to run my wire?
[automerge]1575333614[/automerge]
Just wanted to add that I'm trying to add an electrical outlet to the wall.
Reply to Can I drill through a 4 stud thick column to run one 12/2 wire? in the UK Electrical Forum area at ElectriciansForums.net
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Howdy, I was wiring in a couple LED lights for my trunk bar and diffuser but ran into a maybe problem. The trunk bars wire wasn't long enough for...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
