Discuss Cannot Find Brushed Steel 45 Amp Cooker Control Unit - Vertical? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, hope everyone is well.
I'm looking for a replacement cooker control Unit similar to the one in the picture. I am after a brushed steel or satin one, but I cannot find one anywhere with these vertical dimensions. The tiles behind the socket have already been cut to fit this shape by a not so competent fitter, so would be much easier to replace the control unit with one that matches the back box. I have looked pretty much everywhere I can think of and can only find standard horizontal control units.
Any links to a brushed steel/satin vertical one would be much appreciated.
Cheers
Cheers Jim_e_Jib, A friend had a tile fitter in and what a crappy job he did. If it wasn't for him tiling around the back box, I would of fitted a standard side by side one.
Really need one with a socket, thanks for the response though.
Seems the brushed steel vertical ones with sockets do not exist.
Reply to Cannot Find Brushed Steel 45 Amp Cooker Control Unit - Vertical? in the UK Electrical Forum area at ElectriciansForums.net
A friend has just called as his daughter in Belfast (many, many, many miles from me!) has just lost all power after water fell into the...
5K
Hi all looking for some advice as a non sparky , be gentle :) To be clear I wont be doing the work myself , just want to be better informed. I...
One of these: RS/104 | Wylex 45A Fuse Switch Disconnector, 240V | RS Components - https://uk.rs-online.com/web/p/fuse-switches/1993925/ is in my...
Hi. I have a problem I’d like some advice on, please. If you just want to know the question please go directly to section B of the following. If...
Any one with experience of the FGS Storad heater range and model numbers (installed in a flat built 1993ish I believe). Apart from FGS Storad...
5K
