Discuss Car daytime running lights circuit. in the Auto Electrician Forum area at ElectriciansForums.net
Hello everyone,
I have recently installed daytime running lights on my car by making simple circuit using relay and connecting power to ignition, so lights go on when turn key and go off when I turn on side lights. Everything worked fine. Now I want to modify my circuit so my DRL's would go on when I unlock the car and stay on until I turn sidelights on. I have used two relays in this case, but I'm getting problem with back feed. When unlocking the car my blowers and radio go on, which should normally go when turn ignition on.
this is my original first circuit,
this is new circuit. Could you let me know what to do to stop back feed, I have tried already to put diodes in several places, but with no luck. I also noticed that even when interior lights go off there is still 12v in positive wire. Negative wire has -12v. Is there any other way of designing circuit to do the same thing please? I have basic electrical knowledge, therefore don't know the tricks :) Please help, as I really like to make it and I spent so much time trying to do it with no luck :(
Reply to Car daytime running lights circuit. in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hey all, I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Hi all. I'm trying to put a light-bar on my (facelifted) Land Rover Freelander 2. I'm wanting to wire it so the light-bar will be energised when I...
