Discuss Case for long 600mm to 1000mm Drill Bits. in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
I am looking to buy a case for storing my SDS Bits in . As currently I’m using my car for work and would like a way of transporting them whilst working on the job out of the engineers van.
local carpet shop will give you the cardboard tube from a roll. it's about 4" diameter and free.
This is what I do, use each of the drill boxes to store the appropriately sized bits, then a piece of 50mm pipe with the screwed end pieces - you can usually get the pipe off site and the ends are pretty cheap from screwfix/toolstation
I tried the map/chart/art tube things and they fall apart very quickly.
I don't do much "work", so no van just a car so the same issue as you when I actually have to do something!
That’s a brilliant idea. I’ve ordered these:
wow, the pipe's expensive - anyhow you could make two or three for different sizes/type of bits.
My husband uses the same idea in smaller sizes for tig and sick rods - they are sealed so no issue with moisture killing the flux etc
re: 1st.pic. where can i buy those anti-gravity drill bits?
I have a 16mm and a 25mm one meter SDS bits on the van.
Both are used infrequently but when needed are invaluable.
Not always just for the depth but sometimes to make life easier in the knees.
Reply to Case for long 600mm to 1000mm Drill Bits. in the Electrical Tools and Products area at ElectriciansForums.net
I can't find a previous thread on this topic, so here goes. There is one sort of house-brick that I dread encountering in my area - they are...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I will start my own workshop and therefore trying to know about all the tools i need for an ideal working environment. In my little journey this...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
