Search for tools and product advice,
Discuss Changing Immersion heater control - linking terminals in the UK Electrical Forum area at ElectriciansForums.net
Davidjlondon
I need to change an immersion heater timer control and plan to replace my current control unit (which doesn't have a boost button) to a Horstmann Electronic 7. The installation instructions are in the link below.
http://www.horstmann.co.uk/download...ting/Electronic7-InstallationInstructions.pdf
In these instructions it says link terminals 4 and 5 when using a single immersion heater. What does that mean? Assuming I have Live Out going from either Terminal 4 or Terminal 5 do I just cut a small length of wire and run it across from terminal 4 to terminal 5?
Thanks in advance
Are you an electrician?
Does your immersion heater have an off-peak element as well as the main element?
What that means is that you are using the same element for on and off peak , the actual controller you have can control 2 elements that you find on some tanks , and then the link is not required because each element has its own live out..
Reply to Changing Immersion heater control - linking terminals in the UK Electrical Forum area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi all Have had a request from customer that would like their immersion heater controlled via a Nest. It has standard 2 elements and is not on...
4K
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Hi all looking for a bit of advice. I've been asked to price a rewire for a early 70's build 2 bed apartment. The apartment block was built in the...
Hi all, Yesterday I returned home to no hot water after a few days away. After a brief inspection it seems the fault lies with the Horstmann...
4K
