K
kje
I wanna charge a Dell Latitude E6500 laptop from the cigarette socket (12V), and have now tried two Vanson laptop adapters (SDR-100W and SDR-120W). Both deliver a weak beeping and does not charge the laptop battery.
According to the regular power adapter the Laptop need 19.5V and 4.62A. On the laptop battery it says 19.5V and 3.5A minimum and 4.62A max.
Vanson SDR-100W Vanson Auto Power Adaptor 100W with Adaptors for Laptops Phones MP3 Players | eBay delivers 4.5A at 18/19/20V (you can switch between 18,19 and 20V). The plug fits into the power socket on the laptop and have "positive tip polarity."
attachment.php
Vanson SDR-120W Batterieliminator for laptop, 120W - VANSON | Clas Ohlson delivers up to 6A and can switch between 18,19 and 20V.
attachment.php
I bougth both the Vansons on a local shop here in Norway called Claes Ohlson.
Why do none of these charge my laptop battery?
This is my usual wall adapter:
I have another wall adapter; Vanson SMP-120W like this:
and that works with the same connection into the laptop as I tried with the SDR-100W and SDR-120W.
So why won`t the SDR-100W or SDR-120W charge the laptop? Is it because of wrong power spesifications? Or is it the plug?
I now tried with two other laptops without battery (HP and Acer) with my DC DC step up converter and it worked.
I tried without the battery in my Dell laptop and that worked as well.
But I got a power warning at startup, and it won't charge the battery. I wonder if there is a workaround for that?
Charging Dell laptop from 12V cigarette socket
kje,
amlu,
