Discuss Chasing sockets brick blown in the UK Electrical Forum area at ElectriciansForums.net
i've used floor tile adhesive a few times. it sets like concrete.
My first choice every time ^^^^ If you get the rapid set it will be set hard inside a hour and you can drill and fix into it if so needed. Plasterboard adhesive works well also in a similar fashion. There's also an adhesive called "no more ply mega strength"
Mega Strength Adhesive for No More Ply - http://www.tilegiant.co.uk/mega-strength-adhesive-for-no-more-ply.html
Although its used mainly for a certain application it works really well for a quick fix solution as it sets in 5 minutes and sticks to pretty much anything. Which by the way you have to watch out for as it expands slightly when applied and sticks to everything and is very difficult to remove. each tube comes with disposable gloves because you cannot get it off your skin! (I've found out from experience)!
But because it comes in a tube you can keep it handy on your van. In fact its got me out of many a scrape. I once broke down in my van because the gear linkage plastic coupling fell apart. I used this glue to fix it and was back on my way in 15 mins.
Reply to Chasing sockets brick blown in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have recently moved house and what to replace the garden shed. The shed has some electrics; a double socket with a fused light switch and a...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
Hi, The walls have been chased out and he fitted 25mm back boxes and to be fair you can't really go any deeper but one socket on a ring is feeding...
4K
Hello, My house has 25mm back boxes throughout, but I’ve noticed the previous owner has installed sockets and switches that seem to...
