Discuss Clamp Meter or DMM in the Electrical Tools and Products area at ElectriciansForums.net
N
NathanMorgan
I've been eyeing up either getting the Fluke T5-1000 clamp meter or the Fluke 179 DMM but can't decide what type of tester to get.
Which type of tester do you guys use?
I generally find that measuring current is not too frequent, but it does depend on the area in which you work.
The open jaw ones tend to be less accurate than the closed jaw ones, but if you only need an indication then open jaw is fine.
I find that using a multimeter is more common, but generally just for checking and indicative testing so I tend to aim for a cheap and cheerful one that is not too bad.
The fluke one covers most measurements you are likely to need to measure (unless you have a need for lux or dB for which you probably want a calibrated meter)
small multimeter with volts and continuity for everyday use, senstive dilog earth leakage clamp meter when I need to measure current.
Reply to Clamp Meter or DMM in the Electrical Tools and Products area at ElectriciansForums.net
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
I've got a Fluke 2062 cable tracer. Cracking bit of kit, but very expensive, and isn't getting used very much. I might be open to renting it out...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Saw this on Irish Consumer site (CPCC.ie) HERE Not sure about the rest of the UK but worth checking if you have one. Fluke Europe BV recalls to...
When I use Fluke multimeter clamp-type [true RMS meter] to measure AC current in a 3.5C XLPE cable, does it give the value of leakage current or...
