Guest viewing is limited
Hi everyone,
I have an issue since this morning when I received my order.
The products I bought are:
1. Bande lumineuse RGB 840 LED COB DC12V 24V, 1M 2M 3M 4M 5M, étanche IP67 RA90 4800LM PCB 10MM - AliExpress 39 - https://www.aliexpress.com/item/1005004517150573.html?spm=a2g0o.order_list.order_list_main.16.1df21802VhzCFH
(12V, 5 meters)
2. https://www.aliexpress.com/item/100....order_list.order_list_main.22.1df21802VhzCFH
I connected the black wire to ground, the blue and green together to D and the red one to V
on GPIO16.
I am using a 12V power supply and when I connect it to the controller nothing lights up.
My issue is that I am trying to connect them to WLED app but they don't work.
I set up the wifi and spent a lot of time on LED preferences with no luck.
Attached you will find one of the settings I tried on LED preferences
I contacted the supplier to tell me what type of lights I received but the communication was broken.
I would assume that they are WS2811 but I am not sure. Another detail that I cannot find is regarding the length on the wled app preferences. As I have 5m cable with 840 leds the total number is 4200. Through research I realised that cob led strips come in groups but I am not sure what is the right number. Max number on Wled app is 2048.
I am not sure if I am doing something wrong or the lights simply don't work
Looking forward for your reply
Thank you
GU237DY
United Kingdom
COB Led not working on WLED app
Lighting Forum
Thread Tags
Tags Tags
led
dj unsung,
