Yes, also you said it was possibly 100A cut out fuse should be 25mm tails not 16mm twin and earth easiest solution is to install kmf with 60a fuse and cowl to cover the basic insulation which is supplied with kmfWonder what woudl happen if the customer phoned up and said he/she was reporting them for installing a meter in a dangerous manner ? That might get some reaction !
Hole in the market for clear adaptable boxes? *Kerrching*That would be a VERY well used box!
[automerge]1602014136[/automerge]
Stick a clear sandwich box over it and you have an enclosure and the meter can still be read!![]()
