hi have a query reguarding the possible use of a 240v 16amp commando socket/ plug
i cant find a plug connector( or socket inlet) with a ip rated cover they all appear to be for internal use.Dont really want to fit an enclosure.Customer requires the ability to have power in shed/summer house occaisionaly, does not want or require permenent supply intalled.
i need to attach a socket inlet externally, so customer can connect power easily to the summer house. This inlet will supply x1 DP sw Socket
in theory could you just reverse the socket /plug arrangement as commando sockets are provided with iprated cover
strange one but not sure if the plug and socket can be reversed or does there design restrict this.
yes i see your point didnt think about that, cant find a ip rated socket inlet so i think the only way is going to be via ip rated coupler and socket as you have stated the supply lead will need a socket not a plug connector. thanks tel good point
Commando socket/plug
ianphilip007,
Lucien Nunes,
