Discuss Commando socket/plug in the UK Electrical Forum area at ElectriciansForums.net
hi have a query reguarding the possible use of a 240v 16amp commando socket/ plug
i cant find a plug connector( or socket inlet) with a ip rated cover they all appear to be for internal use.Dont really want to fit an enclosure.Customer requires the ability to have power in shed/summer house occaisionaly, does not want or require permenent supply intalled.
i need to attach a socket inlet externally, so customer can connect power easily to the summer house. This inlet will supply x1 DP sw Socket
in theory could you just reverse the socket /plug arrangement as commando sockets are provided with iprated cover
strange one but not sure if the plug and socket can be reversed or does there design restrict this.
Check out Gewiss as they do many socket up to IP66
even the wong tong ones will keep the water out for a week or so.
yes i see your point didnt think about that, cant find a ip rated socket inlet so i think the only way is going to be via ip rated coupler and socket as you have stated the supply lead will need a socket not a plug connector. thanks tel good point
Have a look at this.
  • GEWISS.pdf
archie, that link shows a plug, not a socket.
Reply to Commando socket/plug in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
For emergency use, when there's a power outage, the current situation (no pun intended) is that I'm running a hook up cable from the 16A socket on...
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
