Guest viewing limit reached
G
GaryM
Is it possible to commission a system (correctly) if there's shading from scaffold across multiple panels.
I'm due to have a system fitted tomorrow and thinking about it, the low winter sun may be obscured by the scaffold.
The scaffold may only pull the performance down, as with any shading issue.
As long as there is enough light to power up the inverter all will be fine.
Commissioning a system if scaffold casuses shadows
GaryM,
SolarCity,
