There are usually codes for wiring types like A would equate to T&E for example. Are they not listed at the bottom of the schedule.
Upvote 0
Look through your Aprendicies in the regs for the way your cable was installed, will have a letter Or nunber.
Upvote 0
There is usually a box at the bottom of the page or if via a computer a drop down box to choose from. Maybe the OP could tell us how he has wired the installation or a photo.
Upvote 0
Have used pvc/pvc double insulated throughout except for feeding garage I used steel wire armoured in the house I used a rating factor of 0.5 because of insulation in most cases the insulation is one side of the cable
Upvote 0
Might help if you noted the configuration of each circuit you have altered or installed.
Upvote 0
T/E is code A. SWA is code F for pvc, code G for XLPE. ( referring to types of wiring, not ref.methods).
Upvote 0
i use Theakston's or Marston's formats beermats.
Upvote 0
