Hello and thanks to all that put this forum together, it is appreciated. My issue should be easy for someone in the know. I have an 80 gallon Champion compressor with a Baldor 7.5HP 3PH 220v motor, it's like new, runs perfectly. I had a cheap VFD on it for two years because residential has no 3PH in the States. The VFD finally died last week so I bought a 15HP, 53A, phase converter. Currently, I have no pressure switch in the circuit. I want/need to upgrade the old Furnas pressure switch as it's not rated for the current config of the unit. I'm guessing there's a switch that can be purchased that will serve my needs I just don't know the specific parameters that I'm looking for. The phase converter has the 220v in, two lines, and the U,V,W out for the motor. I have it hardwired to test functionality and it's good to go. Just need the correct switch and the knowledge of how to wire it correctly. I can upload pics very easily if that would help.
A pressure switch for a compressor would be connected through the control circuit which would carry minimum current.
