Discuss conduit saddle question in the UK Electrical Forum area at ElectriciansForums.net
Avoid using BESA boxes, bend the conduit instead of using an angle box. I think if you need them you could probably get away without a set to the tube if you use distance saddles, hospital saddles however will give more of a gap to the wall.
We use hospital saddles, client wants all boxes floating, so saddles are fixed close to boxes etc.. all for cleaning and it's stainless gear
Reply to conduit saddle question in the UK Electrical Forum area at ElectriciansForums.net
We are installing a new kitchen and the electrician has supplied the electricity under the base units, there is a spur for a socket that will be...
4K
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
I guess there are a thousand question like this, but I couldn't quite get if I can do this myself or need an electrician. I have a garage...
