Discuss Confirming light switch wiring in the Australia area at ElectriciansForums.net
C
Chris_Von_Bron
Hi all,
I am upgrading a Tenby lightswitch to a Marbo dimmer single 2way 400W and would like confirmation of how to wire up the new dimmer. The light is 3x60W (dimmable) so the 400W is certainly within spec.
reverse view of existing light switch
Reverse view of new dimmer
Please can you confirm what goes where?
I will have the deepen the recess so that the deeper dimmer will fit, but I have test wired the dimmer and it works perfectly. Many thanks for the guidance!
read his posts. he's not even a troll. he's a slug.
A 'forum approved' slug?
OK in this instance he resurrected a 5 and a half year old thread for no apparent reason, but that post was deleted. It could have been reported without doing exactly the same thing (posting after it), and the thread could have returned to history.
Reply to Confirming light switch wiring in the Australia area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
Hi, Would like to change existing single pole light switch to attached dimmer switch. I have a live and neutral coming from consumer unit, and...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
Hi All, I have just moved into a new house and the lights in one of the rooms don’t appear to be working, than on top of that I am rubbish at...
