Discuss Confused with Forum Position on DIY in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is there a diy forum where we can go on and ask for advice on things such as;
burning up flat pack furniture,
Shelves , over the workbench
Hanging the kids ,
Putting up pictures of the wife naked on faceache, etc :laughing:
corrected that for you.
On the assumption that the cables in the wall either >50mm or RCD protected. But surely by the rule of nature and evolution, hanging a picture directly above socket / switch before 16th would have helped in the evolution of the human race. Or am I being sinical?
No mate you're being Cynical:tongue::tongue: ,
The ones that I dislike are "I'm not an electrician but when it is all finished I am going to get an electrician to sign it all off for me" but how do I wire these extra sockets to my socket circuit (as they have no way of knowing the existing is a ring or radial or if the socket they are coming off is already a spur off a spur).
Generally I find that DIYers believe that because it works then the job is good. Just highlighting the use of test equipment and the testing involved (and reason for the test) can make them realise a spark is needed. I often tell my customers that the tests are not to check it works but to confirm that it'll stop working when there is a fault. When they do the work they only effectively tick the 'functional check' tick box.
We get all sorts of 'DIYers' ranging from genuinely clueless to people with electronics degrees. We just have to take them as we find them on a case by case basis.
If they're out of their depth and/or they don't have suitable test equipment to prove safety, usually if someone tactfuly explains the pitfalls of the job they're trying to do and the reason they should reconsider they're happy to get some help from a professional. There's been quite a few occasions over the years where forum members have got some work for themselves by constructively engaging with DIY'ers.
An American electrical forum I’m a member of has this in the rules:
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
DIY questions will not be tolerated
You have to bear in mind the American litigation culture, something that is now unfortunately increasing in the UK. Also take in to account NEC codes are statute whereas BS7671 regulations* aren’t.
*A regulation would imply legality although they are in reality a code of practice.
The bottom line is “its up to you if you answer a DIY question”.
Reply to Confused with Forum Position on DIY in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have done some simple wiring in my flat and garden. I joined the forum to see what DIYers are doing. Now having looked around a bit in the DIY...
Hello everyone, I hope you are having a good day. I would like to ask a few questions about the electrician profession and the journey to becoming...
Hi everyone, I just thought I'd say hello since I am new to this forum. I am looking for a complete career change and am set on becoming an...
Are you a skilled electrician looking for a challenging and rewarding career opportunity? We're seeking a dedicated Electrician to join our team...
