Discuss connect 2 lengths of 25mm cable together in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
would be pos to use henley blocks. what if i use cooper tube crimps and heat shrink insulation
frankly you could twist them together and use chewing gum, but do you want proper advice????
Can't see the point of joining meter tails...can you enlighten me?
Ahh ..are you trying to hide the joint ;-)
Reply to connect 2 lengths of 25mm cable together in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I will be putting together 2 x 12v lead acid battery connected in series (24v basically) backup power for Internet connectivity (routers/wifi etc)...
i want to run a something like a BX cable from a sub panel in my garage through an adjacent crawlspace to a fish tank in a room just the other...
Hi! I have a led strip (12V) with an external cable (2*1mm) glued on the wall and it's not fancy at all.. Inside the wall I have 3*1,5mm cable...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
