Discuss Connect chandelier to the downlight power point in the UK Electrical Forum area at ElectriciansForums.net
pgnistru
Hello,
We changed plans with lighting in one zone. Now instead of 4 downlights (square shape of 1400mm side) we want a chandelier. Since downlights are already wired and gyprock installed we cannot wire it up separately to the downlights.
I asked the supervisor to not drill holes so we can do it this way:
  1. Drill one hole to reach to one of the downlight power points in the ceiling
  2. Extend the cable by connecting it to that power point
  3. Install chandelier (there is a supporting timber) in the middle
  4. Then patch the hole
This work will be done by electrician, I wonder if it is ok from safety standards side?
Thank you!
Are you patching/removing the 4 existing downlights (i.e. there will only be the chandelier)?
In principle what you suggest is fine if done correctly, but it seems you are down under so one of our Oz members like @ElectroChem is better placed to discuss Aus regulations.
From a general point of view what matters is any hidden junction boxes are "maintenance free" types as they will not be accessible afterwards, and that the ends of any cables no longer needed due to removed lights are safely terminated (ideally made dead at the source end).
If the run from your switch to any of those lights is free enough then using the old cable to pull through a new longer cable (so no junctons in the roof) is a much better idea, but depending on routing that might not be feasible.
Thank you heaps for your reply!
We are in the construction stage. The power points for the downlights are already installed as well as the gyprock. I asked the supervisor to not make those 4 holes. The intention is to make just one hole to connect to the power point behind it. Other 3 will sit there not connected to anything. In the end we will patch that hole and repaint the ceiling.
The main headache is that the chandelier needs to be hanged about 1 meter away from that power point and it will be hard to get through the lvl beams (it is the ground floor).
Reply to Connect chandelier to the downlight power point in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
I thought I would take a few minutes to give my recent experience in wiring a large garage for power and an alarm circuit. This relates to clipped...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
