Evening all..
I have just changed a CU. I did find a neutral - earth fault prior to the change so I thought I would probably have a tripping RCD.. which I did!
My dilema is how do I proceed with the paperwork?
I'm going back tomorrow morning to do all of the testing and I shall give the required certificates (with a note on regarding neutral/earth fault on downstairs lights), but I get the feeling the chap is going to hunt for the fault himself, the reason being it will require the floorboards being taking up and he doesn't want to incur anymore cost (fault is in a junction box(s), under the floorboards that someone has kindly wired all the downstairs lights from - took me a while to figure this out!)
The main point being that the work is notifiable, but I cant notify it if it still has faults! How do I proceed?
I realise I should have perhaps corrected the fault before the CU change, but the chap just wanted the new CU in and due to my inexperience I wasn't sure if the new CU would trip!
Cheers...
Cheers...
