HappyHippyDad
Supporter
Evening all..
I have just changed a CU. I did find a neutral - earth fault prior to the change so I thought I would probably have a tripping RCD.. which I did!
My dilema is how do I proceed with the paperwork?
I'm going back tomorrow morning to do all of the testing and I shall give the required certificates (with a note on regarding neutral/earth fault on downstairs lights), but I get the feeling the chap is going to hunt for the fault himself, the reason being it will require the floorboards being taking up and he doesn't want to incur anymore cost (fault is in a junction box(s), under the floorboards that someone has kindly wired all the downstairs lights from - took me a while to figure this out!)
The main point being that the work is notifiable, but I cant notify it if it still has faults! How do I proceed?
I realise I should have perhaps corrected the fault before the CU change, but the chap just wanted the new CU in and due to my inexperience I wasn't sure if the new CU would trip!
Cheers...
I've got a cu change next Tuesday which fingers crossed will be ok as it appeared to test out ok, but another that I still have to do had a couple of faults hich really need to be resolved first.
I think all I'd say is you should perhaps have fixed the fault before changing the cu, I know it's not always the way we think, but it tends to make things less complicated.
How is the lighting circuit on if you haven't fixed the fault?
On fixing the fault - let the guy make a start, pulling the boards up, exposing the Jbs, then you should be able to find and fix in no time.... Stick to your original price and put the extra time spent as a learning curve.
Ste
Evening all..
Cheers...
so it must have come as a pleasant surprise then when...holy of holys..:..this happened
so...do you intend to issue paperwork for an uncompleted job?...as thats exactly what it is if the RC bloody D wont hold...isn`t it
I'm not understanding this at all?? If you found that you had a problem prior to changing the CU why didn't you inform the customer at that time?? It's now down to you to sort the problem out, whether you can now charge him for any extra work is another matter. But you can't seriously be thinking of walking away from this installation knowing there is a fault on the installation surely??
this is just rubbish...
this OP IS NOT COMPETENT!!
sorry hippy but i`v read loads of your posts and i wouldn`t let you any where near an electrical installation...
for the life of me:nonod:...
Agreed.
You shoulda informed the client before hand, it's a regular occurance what's happened to be honest - but when you tell mr.smith that the nice new cu will be cutting out because he's got a fault 99% of the time they agree to the additional works. If they don't consent to it, write up a little contract stating that his electrics wont work once you've done the job get him to sign it and walk away laughing.
However...you're probably gonna have to sort this out for free. Remember next time, correct before the CU swap OR at least inform the client. You can fill in the EIC if you really want too, but if someone with a trained eye gets hold of it you're going to look rather silly - as readings will be unacceptable.
Correct the fault, then issue the paperwork. Only option im afraid. Best of luck!
Haha, im impressed glenn ... you held your true feelings in for at least 4posts, but then it came blurting out coz ya couldn't help ya'sen could ya! lol
sorry mark but it needs sayin...
to the OP:
will you just for the love of god please, please shadow someone for a while at least...
Thanks UK, you're quite right... feel quite silly.
quite right too.. Thanks
i dont know if i really should reply to this...
Glenn, theres no way on this earth that you would not be able to reply to this thread!!
Thanks for your blunt, yet correct advice E54, I wont be charging him for the extra work.
I'm sure you'll be able to do the work yourself Glenn, If you really need a hand thats fine but just give a go yourself... you'll be fine! ;)
Agreed.
I kind of got that impression, I did speak to an electrician friend, who said just change it! Also another spark was on site who said this happened to him alot! No excuse for me to get into that habit though!
Yep
Cheers Mark
You need to include this caveat on your quote/estimate:
"NB: Should the testing of the existing circuits find any faults there may be additional charges. Such additions would be discussed with you at the time."
So did you leave them without lights then?
that's all well and good, but he needs to ACtually tell them of any existing faults which is where he let himself down!
