Trouble is though Onions if you read the OP again especially the last paragraph it is pretty worrying, I too 100% Agree with Glenn, he is trying to drum home to HHD just how dangerous his work can be, the fact he was hoping the fault wouldn't trip the board even though he knew it was there is absolutely shocking and he needs to know that even if he is a liked member here.
I did find the bit about turning it on and guess what it tripped bit slightly bizarre. So the OP should also learn not to share everything on open forum some things are best kept to yourself. HHD I wouldn't ever tell you my deepest darkest secrets.
- - - Updated - - -
A dual with spades on the M1 sounds a tad on the dangerous side
- - - Updated - - -
thats the bit that got me started to be honest...
i just looked at it and thought `are you going to cast a spell on the damn thing` or summat like that...
I’m not far from the M1 I’ll be the referee. Onions will have to pick me up on the way.
He’ll win because I’m not walking home!
glenns so hardcore he actually lives on the M1 , just under a bridge past jct 10.
wherever you may roam:
and before theres any snyde comments winging their way over from you biff just remember thats my home your callin..
One cowboy goes in and wires up a JB wrong, then another and does a pointless CU change because he leaves a dead short fault. Now the customer is going to correct the cowboys work!!!
