P
Peter Woodford
Can you tell me when changing a consumer unit I know that the tails have to be changed to 25mm but if you cannot gain acess to the old ones can you just put a notice on the cert. In my case the meter is on the outside of the house and consumer unit is in the garage at high level. The meter is on the outside wall to the kitchen I am thinking the meter tails go up the wall inside the ceiling void a across the kitchen and hallway and into the garage at high level then into a henry block and I was going to
Come out of this with 25mm would this been ok
as it states in osg 2.2.3 minimum size of tails as 25mm2 even though 16mm2 is fine for 60/80 amp feeds
so would this not be a departure from regs
