Discuss Consumer unit replacement in the UK Electrical Forum area at ElectriciansForums.net
If they look like this and are hanging off the wall then maybe...just maybe!
there is a good video thats just popped up on my youtube feed, from that bloke john ward. it covers EICR's and will give you lots of ideas, havent watched it all (its an hour long) but given a lot of his videos are quite informative might be worth a watch and help you understand various points
Reply to Consumer unit replacement in the UK Electrical Forum area at ElectriciansForums.net
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
