Discuss Correct Lock Off Device for 4 Pole Main Switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all & thanks in advance for any feedback.
Could anyone tell me the correct Lock off device used to safely isolate a 4 pole main switch? Screenshot_20190515-110916_Gallery.jpg lockout-lock-slider-pin-mcb-circuit-breaker-lt-spowcbl-new.jpg
I'm not 100% sure if the isolation device with the prongs is the correct device to be used or if another lock off device is necessary.
Pics attached
Thanks all.
The prong one is ok as are the ones that clamp the breaker in place (I use a slightly larger prong type but it's the same principle). Whichever type you use on these main switches they all are easily removed by some one determined to get the switch on.
Reply to Correct Lock Off Device for 4 Pole Main Switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, if I cannot access the line side of a crabtree 100A DP main switch. Would someone enlighten me how to conduct safe isolation on this...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hey all, I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out...
Hi, after a bit of advice. Have tried a lot of plumbing and electrical shops but no one seems able to help. I have an Isolator/PSU 230v/12v. It is...
