Discuss Crank BUT no start relay (85 socket) wiring issue in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Blackpool
Hello guys
I own a BMW E39 which developed a crank no start issue. No codes are being thrown but my initial thought was fuel. So I checked the fuses (all ok) and then moved onto the relays. I removed the relay and its ok then checked the socket and discovered the relay base is showing 4v on the pin 85 socket(which should be ground). All other pin sockets are ok. 30 permanent live, 86 switched live and 87 ground. And the battery seems to be draining down to 11.6v within a day or so.
Any thoughts on what could be producing this voltage on the control side would be appreciated. My thoughts are the electomagnet will not be energising to pull the relay contacts without the ground. The fuses are in the glovebox and the relay is in the boot on the touring.
Thanks in advance
Reply to Crank BUT no start relay (85 socket) wiring issue in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
I'm using the stock fuel pump wiring to trigger two different relays for my two fuel pumps on my car built for drag racing. The first relay is a...
Driving on interstate at 70'ish and dash lights went haywire (check engine, oil change needed, tire pressure warning, etc) all started coming on...
