davesparks
As we're getting more and more work with larger supplies requiring crimped lugs I'm looking at buying a bigger crimper instead of hiring. I'm never sure that the hire ones have been looked after properly and woukd rather have something I can trust.
Trouble is I can afford a hydraulic one so are the manual ones up to scratch? I can't see any reason why the wouldn't be but thought I'd see what the vast experience of the forum has to say.
I'm looking at this hex type at the moment:
Then I noticed that the old style indent crimper are still available, I thought they'd fallen out of use years ago for anything but solid cores, are they still a viable option?
Got an old BICC SET 6mm, 16mm, 25mm, 35mm,50mm, 95mm, 120mm if you want them they are FOC but need collecting from my house let me know.
I'd always go for hex pattern crimpers.
I bought some that are identical to your picture but they were pretty shoddy. Were about £12 from ebay though :rolleyes:.
The circlips that hold the die axles in fell off in a very short time resulting in the parts coming loose. I only got them for occasional bonding lugs for my domestic work, but still.
Apart from that the action of the design was very good and easy to crimp, so a better quality brand of the same design might be a good shout.
Depends on what size you need an how often. Anything over 150mm can be a real PITA especially in a cramped environment if they are not hydraulic.
Can pick up sets up to 300mm fairly cheap nowadays <300quid. Or look into Petes offer.
I would always use hex crimps for stranded conductors.
Apart from crimping a few types of terminal that require a dedicated die set, I use two manual tools, one hex, one indent. The hex is a ratchet tool that takes dies from 10 to 120mm. I like it because it's heavily built and smooth to operate. One handle is fixed to the body so in awkward spaces you can park it in position and just push the other one repeatedly until the crimp is complete. The indent tool is adjustable from 10-95mm, single stroke type with 2' long handles.
Both are 25+ years old, can't recall where they came from although newer versions of them are still available from RS / Specialised Wiring Accs. I'm not specifically recommending them over any others, but they have served well
Thankfully mine is not in those hideous colours!
Howcome? I've been reading a few different articles and they all seem to suggest that indent are equally suitable for stranded or fine stranded as hex crimps.
And my own experience is that I've not yet come across either which have failed (apart from where some muppet has fitted oversized lugs)
I've looked at the ratchet ones you mention from SWA.
What influences your decision to use hex over indent or the other way around?
Personal preference rather than a hard solid fact. I tend to use indents for large Al and solid copper conductors.
I personally feel that the cold weld process is more thorough with an all around hex style crimp.
My experience with those hand Hex crimpers shown in the OP, is that you always have to use the size below what you are crimping.
If you do ever contemplate purchasing a hydraulic set, steer clear of Cembre.
They use some weird numbering system for the dies, which doesn’t seem to relate to anything.
I have bought one of the hydraulic ones from a well known auction site, I find like someone else mentioned that you have to use a size smaller than labelled. Otherwise, I was happy with the results, used for 1 job with some 70mm swa. Now rests in shed for next job in another 3years. Hence not wanting to spend on well known make.
That may be due to the make of lug you are using?
Slightly off-topic, but I am astounded by the poor quality of items available nowadays such as brass bushes, couplers etc, the same with some tin like lugs.
Normally use hex for straight forward lugs onto cable ends, but in special situations inside equipment, where I want fine control over the amount of deformation e.g. because the terminal and conductor are not an ideal pairing, I use the indent.
Crimper manual/hydraulic hex/indent?
Thread Tags
davesparks,
Bellendian,
