Discuss Crimping tool in the Electrical Tools and Products area at ElectriciansForums.net
I understand that good connection is desirable, but I can't afford to pay 50$ or pounds, or euros, just to crimp 2-3 wires. That's just not acceptable. I will crimp it with tool I have, or with the one I suggested to buy. I have tried them, and I am sure it will hold for longer period of time. If someone has better solution, then I will reconsider.
If you only need a couple crimped then why not pay a local sparky or garage a couple of Euro (or a beer) to do it for you?
Spending even 5 Euro on a rubbish crimp tool for a couple of connections only does not make sense!
I tried to crimp this small wire into but connector 1.5 mm, but wire is too small and I can't crimp it good. I don't know what the size of wire is.
What should I do with the wire, should I fold it back down the wire insulation and crimp all of it?
You can fold back the conductor to crimp that with the metal part more effectively, but it is not a good idea to have any insulation in the conductor crimp section as the whole point of a reliable crimp joint is there is sufficient compression pressure to cold-weld the conductors together.
Not really. For a start they used different crimp tools - the "bad" one was not done with the correct style of crimp.
Also the red terminals should work for 0.5mm-1.5mm cable size, and if you double-back the conductor that is down to 0.25mm which is very thin, well below what is suitable for any sort of power (current rating around 2A or so). If the doubled-over conductor is not holding then it is simply a lack of crimp force!
I tried to even fold wire 2x, but I just can't crimp it good, connector doesn't even hold the wire, yet alone compress it.
I refer you back to the original discussion about how rubbish those crimp tools are :(
I tried tool in #1. I can see that crimping space is higher then in tool in #11. I can buy tool #11 but I don't know if that's going to be better. Honestly, I think wire is too thin to be crimped in but connector, I might have to consider some other joint.
It will not.
Look for a cheap ratchet style tool in your local DIY or automotive accessory type shops if you want something better.
Try folding the wire twice (i.e. to 4 * original thickness).
Use uninsulated crimps, solder the wire in and use heat shrink sleeving.
Could have done them all in less time than it takes to post on here ?
I don't know to solder.
I could only twist wires together, and use heat shrink with lighter.
[automerge]1590241197[/automerge]
What diameter of heat shrink sleeve should I use with there wires that are about 1 mm in diameter ?
Reply to Crimping tool in the Electrical Tools and Products area at ElectriciansForums.net
Hello everyone. What tool would I need if I were to work on a construction site doing containments? Thank you
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
Register your Klein Tools online today to access tool details and protect yourself against tool theft! If you own Klein Tools in the USA or the...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Inspired by another thread, which I don't wish hi-jack. Can anyone recommend a decent, relatively low price punch down tool? I've had a cheap...
