Discuss CU Change for assessment in the Australia area at ElectriciansForums.net
L
liam b
Ive changed a CU for my assessment and rewired the upstairs lights due to no cpc,
will the assessor want to see calculations for cable size and voltage drop for rewiring the lights?
and will he want max demand/diversity calculations for the CU
and on the inspections, what happens if a box gets a 'x' do i need to put it right?
thanks in advance.
NO, but he will want to know if you know how to work it out and if you dont how you can find it out..
big hint is have the PC on and take him to TLC website and click technical section...! ;)
probably not
you will be expected to carry out a handfull of tests on your work to prove to him you can do them..! they normally very helpful and if you do get a bad mark that requires attention they will tell you what you need to do and let you do it there and then if time allows or to take photo evidence and send to them.
thanks in advance.
hope this helps
Reply to CU Change for assessment in the Australia area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Need help check that my cable calculations are correct as still new to doing them. 6A Lighting Circuit 60898 MCB Type B wiring in 1MM²/1MM² T+E...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
