I
iamelectric
whats the script with dado trunking and rcd protection , i have a job to do , old mem board , cant get an rcbo for it so i was going to use swa from board to first socket in dado ( all concealed so wouldnt see it ) and then t&e to the next 2 sockets and use rcd sockets , does unprotected cables in dado need rcd protection? thanks
No, its surface mounted, so you can see where it is. Assuming all is well with earthing etc
so does a circuit in pvc conduit run on the surface not need rcd protection ?
Again no because it's on the surface...
Only cables buried in walls less than 50mm does it apply too...(there are exclusions)...
Although the socket itself may need RCD protection depending on its use and location...
