Power Distribution Unit? I thought they were just bigger and more expensive extension cables...
Power distribution units can come with more socket outlets and are designed (to some extent) for the job you describe (supplying multiple items of low draw IT equipment), they are more robust than multi gang extensions and would avoid the requirement for lots of plug and socket connections which increase the chance of high resistance problems and failures.
However the best idea is to wire it properly.
The twin and earth cable in the plug top is not designed for plug tops and trailing over floors, flex would be much more appropriate.
Coils of cable drawing current through them as in picture 2 are bonfires waiting to happen. Magnetic effects cause overheating and dramatically reduce the current carrying capacity of the cable.
You cannot accurately measure current leakage with a multimeter, you need an earth leakage meter.
What is the RCD you are conscious of tripping ? what does it serve ? what problems arise upon it tripping ?
Oh and you definitely need some more sockets fitting lol.
two things if say looking at those pics.
1) unwind all the cables instead of coiling them up like that.
2) not quite sure what's plugged into the 3rd socket on 4th pic, but looks like nothing is attached. I'd switch anything off that's not in use. each one is switched, so may as well take advantage of that
This is the problem with the part P rubbish it leads to more and more of these lash ups as its all easy to do and no need to register with anyone, suppose you could run these all over your house with a 13amp fuse protecting everything, maybe run 1 for upstairs and 1 for downstairs off the 1 ring and the same off the other ring (if you have 2 rings) you could have all the sockets you want lol
I would love to have more sockets, though it's rented accommodation and they don't see the point in extra sockets. One double socket in each room in a awkward location.
Also the CU is padlocked, and they charge to come out and reset things...
wtf? for real?! so if an mcb trips at 2am, you have to call someone to come out and reset it for you and charge you for it? who exactly would come out anyway. landlord/lady, sparky?
That's totally unreasonable!
If you say where you are, someone on here may be able to call round and do some earth leakage measurements (for a modest fee). You can't (safely) do this with a multimeter, you need a sensitive earth leakage clamp ammeter round the relevant supply conductors or CPC.
