Doing a bit of work for a family member, fuseboard change etc..
Having a look around I found that the DB is a bakelite, wooden backed wylex 10mm tails 4mm earth.
All earthing is in black cable.
No bonding
Lighting circuits have no earths
Many switches are round on wooden pattresses
Oval-ish shaped bakelite MK sockets on wooden pattresses
PVC twin, 3cores have white has L2
Anyone guess a date just out of interest? they seem to think it is from 1961.
Problem I have is the lighting circuits, I can rewire the feeds but not the switchwires, as they are clipped, painted, caulked, painted and painted onto the door frames of recently decorated rooms and are extremely awkward to remove!
Is this worth doing?
Or should I just convince them to change the odd metal fitting back to pendants/class 2 fittings?
EDIT:- Forgot to mention IR is fine, well over 100 mOHms
No bonding
