Discuss dead wires for outside light in the UK Electrical Forum area at ElectriciansForums.net
Hello. We bought a 1966 house recently. 1 outside light at our side door was old/broken so I bought a replacement. Before removing the light I used a voltage tester so I’d know which breaker to shut off. That didn’t work. I unscrewed the fixture from the wall, and found the light wired and capped as it should be to wires in the wall.
I used 2 different voltage detectors, nothing.
I removed the caps and tried the detectors – nothing.
I don’t know what breaker this fixture should be on, but all breakers were on when I disconnected the wires. I don’t know how to trace the wires in the wall and I don’t know how to get power to this light fixture. The light is at a door for a breezeway and garage that was added on in 2008.
All other add on lights and outlets work just fine.
This one light that we need at night has no power and I have no idea why.
Any thoughts or suggestions?
Thank you for your time!
JR
JR
It could be made up and have GFCI protection which could be tripped
There's a strong possibility of a broken connection. If all the other lights and outlets work then this fixture is likely to be at the end of the run and the break might be in the next-to-last fitting that is itself working. Of course it could equally be in a hidden joint box or a damaged cable, but I would check other nearby fittings first for a wire broken free from its wirenut or similar problem.
If that fails, then with suitable test equipment it is sometimes possible to trace approximately the run of cable using a tone generator and search coil. That would at least show where it is supposed to be getting power from. Not much help if it is broken somewhere completely inaccessible. Then it is a question of whether it is easier to fix the problem or just run a new feed.
thank you, I'll give this a go, as far as I can go with it at least
JR
Again it’s not unusual for the outside flood lights to not have a switch, especially if the setting is dawn to dusk and you use your breaker as a disconnect so you can work on it
Reply to dead wires for outside light in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
